All Original 1938 Steam System Complete With Original Heating Blue Prints
New England SteamWorks
Member Posts: 1,529
Nice find. New owner. Beautifully installed system. Not, however, terribly efficient: Time for steam to header: 33 minutes. Time for mains to vent: Unknown. I had to give up after 40 minutes! Radiation is recessed Arco cast iron convectors. New owner is removing the convector grills, sandblasting, and powder-coating. Should come out looking very nice.
Owner wants to stay with oil: MegaSteam Dreamin'!
newenglandsteamworks.com
1
I'll try and post a picture of the original blueprints. Pretty cool to have.
I am thinking wrap-around header to pick up the 3 supply mains.New England SteamWorks
newenglandsteamworks.com0 -
What kind of boiler is that (Thatcher?) , my old Delco had that same pressure gauge. The original prints would be very interesting.
3PSI gauge0 -
Do post a picture of the blueprints -- I'd love to see them!
One wonders what can be done to decrease the time to venting -- although seven minutes from steam in the header may not be all that bad, it should be better -- IMHO. But 33 minutes to develop steam? Eeek.
Wonderful find -- and it must be nice to have a client who seems interested!Br. Jamie, osb
That boiler either has a hole above the waterline, or it's full of soot, or the burner is way underfired, or it was never baffled properly.RI_SteamWorks said:Time for steam to header: 33 minutes. Time for mains to vent: Unknown. I had to give up after 40 minutes!
We replaced a similar boiler with a MegaSteam some years ago- huge improvement!
Consulting0 -
Boiler is (was) a Weil Mclain. 40 minutes + to vent was after steam got to the header! I suspect it was a combination of all three Frank.New England SteamWorks
Here's a blueprint shot. There's another 2 pages for 1st & 2nd flrs with Arco model numbers and EDRs.New England SteamWorks
newenglandsteamworks.com1 -
Meanwhile, Master Pipe Fitter Nelson (aka Paganini) unleashed the magic pipe wrenchesNew England SteamWorks
newenglandsteamworks.com3 -
The original boiler had a Quiet May. Nice!Retired and loving it.0
Dan's most famous quote? "High pressure goes to low pressure. Always".
2nd most famous: "Underground returns are guilty until proven innocent".
A good defense lawyer in his spare time, Paganini put down his pipe wrenches and sought to prove the returns innocent with a more industrious tool than his standard wrenchesNew England SteamWorks
Betting against Dan is never a good propositionNew England SteamWorks
Well done, guys.Retired and loving it.0
Not easy, but supply mains all tied in.New England SteamWorks
It looks Great!0
great job RI!!ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Good as it gets.Retired and loving it.0
Nice work. Can't wait to see the usage numbers next season...
Had to go look that one up. Fascinating.DanHolohan said:The original boiler had a Quiet May.
Quiet May killed the coal-fired boiler business. That company was brilliant.Retired and loving it.0
And IIRC, that company was located right here in Baltimore.DanHolohan said:Quiet May killed the coal-fired boiler business. That company was brilliant.
Consulting0 -
Roth tank in today.
Poor Ilka. She got fixed on Tuesday and the Vet told her no boiler installs for two weeks. That lasted about 2 days, naturally...New England SteamWorks
Is she still talking to you?
3PSI gauge0 -
Ha! On day one, no Bob. On Day two: no (she knew it was a MegaSteam). In the afternoon we both crumbled: she spoke, and she got to MegaSteam...
Don't tell the Vet...New England SteamWorks
Just curious. In the picture of the boiler installed at site, what's the thinking with the 2 main takeoffs on the left being oversized and then reduced just before the king valves? Instead of being brought down same size all the way to the header?0
Dan's book Greening Steam, Page 94 explains it Abracadabra.New England SteamWorks
reducing velocity into the takeoff, keeping water in the header, dryer steam. got it.RI_SteamWorks said:Dan's book Greening Steam, Page 94 explains it Abracadabra.
That is one great looking installation! You set the bar high
gwgillplumbingandheating.com
You are too kind Gerry. Truth is, when I need inspiration I always turn to your website. Imitation, after all, is the sincerest form of flattery:New England SteamWorks
It's a wrap:New England SteamWorks
newenglandsteamworks.com2 -
Nice job!!! @RI_SteamWorks ...I like the way you use Gerry's trenching idea for the wet return and the wye strainers before the GortonsASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Oh. How about an ode to The Dead Men:New England SteamWorks
Lastly, a Caption Contest:New England SteamWorks
Superb!Retired and loving it.0
I hope Ilka will be a contributor here as well!--NBC0
That picture immediately made me think of this picture from the old RCA ads. Even has the head tilt down.
1
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
