Oh-Oh: A Leaker in February w/ 12 Apartments! Who you gonna call?!
New England SteamWorks
Member Posts: 1,529
More tomorrow.
newenglandsteamworks.com
1
Waiting to see the finished install!0
What size header is that?
Where's the skim port?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Have you established a relationship with a service provider? That would be far best.0
Look. At least it's not last winter -- although the forecast I saw suggests snow for tomorrow!Br. Jamie, osb
Master pipe-fitter Nelson watches the weather and makes preparations...New England SteamWorks
newenglandsteamworks.com0 -
At least the vents are good and we don't have to open them up...New England SteamWorks
Well, at least the weather is pleasant...New England SteamWorks
This building has been keeping it all in for 80 years...New England SteamWorks
Are we finished yet?New England SteamWorks
Nice! Do you have a little pitch on that antler with the 3 Gorton #2's?0
There are two sides to every boilerNew England SteamWorks
Many happy returnsNew England SteamWorks
newenglandsteamworks.com1 -
Ever hear of the "D" dimension?New England SteamWorks
Very Nice!0
Very nice looking! On the gas, your inspection people are good with the Trac running like that? We generally would run a nip to the ceiling, run a short nip and anchor it, then Trac it.
Keep up the good work0 -
Looking nice!!!! Of course on an EGH-95 I'd've run a 5" header but I like big pipes lol......DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
We would have used a 4" header if we had known the tappings were 3". But it was (obviously) a rush job so we had to go before we had the boiler and the I/O Manual states 2-1/2" tappings. With such a low boiler, we liked going with extra tall risers and just upping the header to 3". Would have been fine.
But then the boiler shows up w/ 3" tappings. We had to ditch the 2-1/2" risers and reducing elbows and go to 3". No time for a 4" header when the 3" header was ready to go. But again, with such a low boiler, I think we got it all back in height.New England SteamWorks
Yeah you guys will probably be fine. I go overboard sometimes. LolDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Well Dave, always remember: nothings succeeds like excess! Especially with a tight "A" dimension.
Although I confess that I am getting a bit long in the tooth for 5" pipe!New England SteamWorks
Ystrainer before the vents ,nice idea
Looks great! No auto flue damper?1926 1000EDR Mouat 2 pipe vapor system,1957 Bryant Boiler 463,000 BTU input, Natural vacuum operation with single solenoid vent, Custom PLC control0
just curious..did you change this to a low pressure gas system? seem to remember a maxitrol on the old one or was that just for the burner?0
- 167 Indoor-Air Quality
