Switching 240V 5KW garage heater
Hence my initial suggestion to put the SSR or relay inside the appliance. Adding a control point to the appliance is not a bad thing.ratio said:If that second schematic is the correct one, the plan to break both hots external to the heater will most likely cause problems. There's a fan switch that holds the fan on after the elements drop out to cool them off. If the fan drops out before the elements are cool enough, the high limit will trip.
If you use a SSR make sure it's on a good heatsink.
3PSI gauge0 -
Here's what I've got so far.
The heater should have a disconnect as well. Might as well incorporate that into the whole thing.0
The finished product.
Not bad for homemade in my opinion.
@MarkS does much nicer work but it's reliable and more importantly it's safe.
The funny part is it could in theory control two 11,000 watt heaters and it's only controlling a single 5000 watt one.I chose that contactor (40A DPST) because of price and dimensions.
Nice looks good.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 968 Plumbing
- 385 Solar
- 15.3K Strictly Steam
