Leaking gorton vent
My previous home (1903 Victorian) had the pocket doors that were great at keeping rooms closed off and even warm. HUGE open staircase that led the heat straight upstairs. My current home (1929 Colonial) has rooms that can be closed off with glass French doors on the first floor and a NON OPEN floor plan (thank God). Staircase is not as open but also funnels a lot of heat upstairs. I'm blessed the house has been unmolested from its original floor plan as was my 1903. Sometimes you just have to accept that heat rises! And the 2nd floor is a bit warmer.
I wouldn't trade my steam heat/radiators for nuthin'!0 -
The nice thing about pocket doors is just knowing that they're there.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
You are so right. Don't make me think about itDave in QCA said:The nice thing about pocket doors is just knowing that they're there.
Fred, you're right. I have an open staircase. Most of the time when it's not terribly cold outside (ie 25-30 degrees) the temp difference is maximum 1 degree. I also have a third floor with electric baseboards but I never turn them on as the heat from the second floor is enough to heat that third floor room.0
Electric baseboard will be costly to run all the time. If you have a way to close a door to the third floor or somehow close it off for a couple days, do so and see what that does for the temps on the second floor.0
The previous owner took the pocket doors with him, so I took out the wall it just didn't make sense anymore. The funny thing, he left the hardware and from my research I got the "good" part. Apparently I have some very rare pocket door hardware (see pictures). Payson Pendulum never seen anything like it and there is only a tiny bit of stuff online I could find out about it. I can say this the hardware runs smooth as silk. I am going to reuse a couple of them for my daughters bedroom closet door. No track and saves some space...and it looks cool!
They just don't build houses like they used to.0
Fred, I have a door to the third floor. That is a guest room so I usually keep it closed and open it whenever we expect somebody to stay overnight. It's my second year in my house and I've never ran the baseboards yet.0
They do, I think you just need to pay more for higher quality materials and workmanship. My realtor, who sold me my house, is an owner of a construction firm and they build new houses in the area. They're more expensive but their houses are top notch and they have nice plan/layout of the houses.jbmoff said:They just don't build houses like they used to.
@RomanGK_26986764589
I agree about paying more. BUT, there's just " something" about a house built before the 1950s that screamed solid construction, charm, and craftsmanship that, no matter what, cannot seem to be duplicated with today's work.1 -
A lot of the old houses in this area used basswood for the trim. It's a tough wood that takes a nice finish and gets very hard as it ages - don't try mounting a curtain rod with nails, won't work unless you predrill.
There is also no substitute for old growth fir framing (when 2X4's measured 2.0 X 4.0); their not making that anymore. I replaced a cellar window a few years back that dad been sitting in the dirt for 90 years, the surface looked pretty bad but 1/8" down it was like new.
3PSI gauge0 -
Even the old Douglas Fir pine they often used for doors and even trim was beautifully grained and durable. My current home has chestnut trim that cannot be beat. Too bad the previous owners painted it white. :'(
All the houses on my street still have their UNPAINTED chestnut that is just gorgeous, old growth wood.
Try and find that at Home Cheapo...
- 167 Indoor-Air Quality
