Steam heat is amazing...
124
  • ChrisJ
    ChrisJ Member Posts: 16,706
    Gordy said:
    The behemoth boiler in the basement, and low hanging pipes is why most want to b rid of it. Gain space in the basement.
    Yeah....
    I look at the space duct work takes up for forced hot air and my steam mains are tiny.
    The runs up to the second floor are micro compared to the ductwork you'd need.
    Low hanging, yes, but no lower than the bottom of those ducts will be. For hot water, yes, you win the argument. For 93% of America you lose.
    Gordy
  • BobC
    BobC Member Posts: 5,521
    @KC_Jones
    I was just listening to this as I read your post -
    Big Chief Pontiac - Omar Kent Dykes
    Bob
    3PSI gauge
  • Canucker
    Canucker Member Posts: 723
    ChrisJ said:
    Yeah....
    I got rid of the old gravity piping in my basement for exactly the reason @Gordy states. No hot air though, for exactly the reason you stated, although hot air was a suggestion while looking around for someone that could do the work. Haven't been able to mimic what I had before with the constant circulation through the old gravity set up, more on off now and I can feel the over and undershoot from the new set up. I imagine that would disappear with a properly sized mod con and long firing cycles
    You can have it good, fast or cheap. Pick two
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,414
    You could try using an Energy Manager on your boiler to reduce water temperature. That would increase the run time on a cycle but would even out the heat.
    cell # 413-841-6726
  • Canucker
    I wondered if it was control based. It seemed once it was zoned and the new Honeywell stats were installed, it was never as even as the t87 that got replaced. Oh, and to stay on topic, I agree that steam heat is amazing :)
  • Fred
    Fred Member Posts: 8,542
    Oh, and to stay on topic, I agree that steam heat is amazing That's what I'm talking bout! :)
    Canucker
  • ChrisJ
    You want to know why steam heat really is amazing?
    It can operate with NO moving parts and NO electric.
  • ChrisJ
    Yeah.....right.
    Try and start the EG-40 without electric.
    Good luck with that.
    Oh,
    So you don't think I can hunt down a millivolt setup for an EG-40? Seriously?
    Where's my damn microphone so I can drop it again.
    I can get all the parts to send you Chris. You will need to remove your electric damper first.
    cell # 413-841-6726
    ChrisJ
  • ChrisJ
    Nope, I do not.
    @Hatterasguy ??
  • Gordy
    Gordy Member Posts: 9,546
    Pick up the Mic. Vents have no moving parts........come on.
    Hatterasguy
  • hvacfreak2
    hvacfreak2 Member Posts: 500
    edited January 2016
    I do not believe that a mechanical lwco that is correctly installed and ul listed should not be an issue. My boiler offers that as an option ( field installed ) and includes install instructions in the iom. I believe that there are vent dampers with end switches or enough of a shaft to accept an end switch.
    You could wire those devices parallel with the existing devices , a couple of mechanical switches to manually change over in case of an outage. A manual switch to call for heat ( or enable a mv stat ) and make steam with no electricity , too cool.
    hvacfreak
    Mechanical Enthusiast
    Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV's
    Easyio FG20 Controller
    ChrisJ
  • ChrisJ
    Just to be clear.
    You don't need automatic vents for steam heat to work.
    The silver soldered system I'd love to build would not have any vents.
    My statement stands.
  • ChrisJ
    Be sure to include the 67. He's going to need it.
    I'm sure Charles Garrity is well aware a MM #67 is required. I have no intention in converting my boiler to a millivolt system, the point was I could.
    Use a float type lwco.
    cell # 413-841-6726
  • ChrisJ
    You cannot convert it to millivolt without eliminating all safety devices provided by the manufacturer. If you still want to go ahead with that, knock yourself out. If you have no intention of doing it, why make the statement in the first place?
    The statement was ridiculous and you know it.
    I made the statement because it's possible and is in every way a benefit of a conventional steam boiler vs your great modcon.
    Not only that, the MM #67 is plenty safe and I would have no problem relying on one again.
    Spill switches work on milli volt systems too
    cell # 413-841-6726
    ChrisJ
  • ChrisJ
    Stop egging him on.
    You're missing the point about the fact that he cannot legally modify the EG-40 to that configuration without jeopardizing his insurance on it.
    And you shouldn't keep supporting him in this quest.
    Wait.
    Why can't I?
    All of the safeties would still work. Converting from a LESS RELIABLE probe LWCO to a more respected float type is a problem?
    You lost, admit it. :)
  • KC_Jones
    KC_Jones Member Posts: 5,883
    Hat he already modified the gas train on his boiler. How do you think the insurance company would react to that? lol Let's do it Chris, I will come over and help. ;)
    2014 Weil Mclain EG-40
    ChrisJ
  • ChrisJ
    When you make the change, and post it on here, I will admit I "lost".
    I will also pray that you never have a fire in your house for any reason whatsoever.
    You should be praying I never get a fire in my house anyway.
    That's not right man. I always hope for the best with you and your family.
    You hurt my feeling. :'(
    Hatterasguy
  • ChrisJ
    Actually I didn't, you did.
    My gas train is 100% stock as per WM specifications. Except for the union.
  • KC_Jones
    We aren't talking about me so shush.
  • MarkS
    MarkS Member Posts: 75
    Millivolt systems operate using a principle known as ... wait for it ... electricity. A tiny amount, to be sure, but nonetheless electric.
    Gas valves by definition have moving parts. As does the relay in your thermostat, and even the mechanism in an old reliable T87.
    Up up and awayyyyyy!
    1890 near-vapor one pipe steam system | Operating pressure: 0.25 oz | 607 sf EDR
    Midco LNB-250 Modulating Gas Burner | EcoSteam ES-50 modulating controls | 70 to 300 MBH |
    3009 sf | 3 floors | 14 radiators | Utica SFE boiler | 4 mains, 135 ft | Gorton & B&J Big Mouth vents
    ChrisJ
  • ChrisJ
    That's it, you're getting oatmeal the next time you visit. :)
    MarkSHatterasguyCanuckerKC_Jones
    self generated electricity. Therefore it does not need electricity, it makes it's own. Drop the mike
    cell # 413-841-6726
    ChrisJZman
  • Gordy
    edited January 2016
    Technically an old gravity hot water system once setup had less moving parts than a steam system.
    Unless you want to count the water in the pipes.
    Let me drop that Mike for ya.
    Steamhead Member Posts: 17,781
    It still had a vent on each radiator (unless it was an overhead system). But the Tudor System didn't have vents or traps on the rads.
    Consulting
    ChrisJ
  • Abracadabra
    Got called into an emergency last night where a 39-unit building lost power for 36 hours. Chicago temps were in the mid 20s... Brought in a small honda 1kw inverter generator and got the steam boiler going again. Good luck heating that building with anything near a 1kw generator using anything other than steam.
    GordyFredChrisJ
  • Fred
    AWESOME!! I keep one just for that purpose!
  • ChrisJ
    I have a tiny 12V to 120V inverter and alligator clips I can clip to my car battery to run the boiler if need be. We also have a 4KW Coleman generator from the early 90s that sounds like a dump truck going through a nitroglycerin plant to run during the day if we have a long term outage. But the fact I don't have to run it for heat is nice. I forget what I figured out, but I think my car's battery will run the boiler without charging it for something like 4 or 5 days easy.
  • SWEI
    SWEI Member Posts: 7,348
    Modern hot water systems (at least the ones we design and install) don't consume a lot of electrical energy. I'd be surprised if our largest project draws more than 1 kW at full tilt (3x 399k mod/cons, 100+ radiators and control valves.) Next time we're out there, I'll put a meter on the subpanel that feeds the boiler room and see what it tells me.
  • Fred
    Same here @ChrisJ . I also have a 17KW generator for possible extended outages. I have a 9KW and an 8KW generator that I got a really great deal on, one is diesel fuel the other two are gas. I bought the two as back-up for my son's home and my sister's home. None have been used yet! A few years ago we had a storm that knocked power out for two weeks all around me. My block was the only one in the area that did not loose power. Talk about disappointment :)
  • ChrisJ
    edited January 2016
    1,000 watts! :)
    If I recall my boiler alone consumes around 12 watts. Going off of the measurement I took when setting the mercury T-87 I used to have but I seem to recall 0.5A @ 24V.
    This could be lowered if you remove the damper and probe type LWCO. Not sure how much those draw, but it's something.
  • Gordy
    With that being said if you have a 1kw generator then no difference if the system needs 10 watts, or 1k.
  • ChrisJ
    1000 watts will use substantially more fuel than 10 watts. 1000 watts also will not last very long with a battery + inverter.
  • Gordy
    edited January 2016
    If a generator is used its running whether it's 1k or 100 watts. It may use a little more fuel at full output, but not much. They kick up to high rpm no matter what you plug in.
  • Gordy
    I'll bet a Honda 1k generator is lighter than a battery, or the same, and when your battery is dead I just dump more gas in, and pull the cord. Runs 8 hours on a gallon of gas. Then you can plug your trickle charger into my generator, or grab another battery out of a car.
  • ChrisJ
    edited January 2016
    So you feel a generator consumes the same amount of fuel with it's throttle plate almost shut, as it does close to wide open?
    Seriously?
    I suppose your car consumes the same amount of fuel floored as it does idling.
    After hurricane Sandy people were lined up at gas stations waiting to get gas for use in their generators, or sometimes cars.
    I wasn't one of those people, not once.
    And, my car battery is bolted in my car so I don't care what it weighs. I clip onto it, close the hood and connect my boiler. Voila, heat. See, drawing 12 watts means you can easily run 50 feet of 18AWG wire without concern. It makes no noise at all, and consumes no fuel while the boiler isn't running.
  • ChrisJ
  • SWEI
    All synchronous AC gensets suffer from relatively high fuel consumption even at zero or near-zero loads. Carbureted gas engines suffer the most; direct-injected Diesels not so much.
    Inverter gensets vary their engine RPM over a fairly wide range, so their fuel consumption tracks the electrical load far better.
    Watts per square foot is probably a decent measure of this stuff. I'll try to get a number from the hotel job next week.
