Thatcher furnace
I have a vintage Thatcher Model G-70 series 1 gas furnace steam. It is leaking water from the rear of the unit. Can the unit part that is leaking be replaced?. If so, where can I buy the parts? Or, at worst, where can I buy a similar Thatcher unit in good condition? Thank you.
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Sorry I doubt any parts are available.
    delta TZman
  • vintagefurnace
    vintagefurnace Member Posts: 14
    How about another system in good condition , if not , then for the parts
  • Tim McElwain
    You will need a new boiler.
    delta TZman
  • John Mills_5
    John Mills_5 Member Posts: 952
    Come on, splurge on a new 85% boiler! Stop throwing 1/2 your gas up the chimney!
    delta T
  • This content has been removed.
  • vintagefurnace
    Is it possible to obtain parts for a Thatcher G-70 Series 1 steam boiler? If not, do you know where I might be able to find another Thatcher unit? Thank you.
  • STEVEusaPA
    How many different ways are you going to ask the same question?
    Canucker
  • ratio
    ratio Member Posts: 4,176
    Is there some reason why this "vintage" (as you put it) boiler must be repaired, instead of replaced as suggested by the professionals above? Pictures always help.
    Steamhead Member Posts: 18,209
    No. That company went out of business probably decades ago.
    Consulting
