Piping and component labeling
Steve Minnich
Member Posts: 2,868
Most of the commercial work we're picking up is requiring us to label just about everything. This is a picture of my first stab at it. I've looked at labeling devices specific to this purpose and the cost is like a grand. That's seems crazy to me. I'm open to any and all suggestions.
Steve Minnich
I guess one just has to charge accordingly Stephen . I'll bet there is a spec of what type of material and chain the tags must be identified with also .
Always something more every time we turn around .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Very nice indeed. If they require metal, I've used the kind of soft copper tag sold for gardeners to label stuff with, and written on it with a stylus. Since my handwriting is atrocious, it's not that useful, but you'd probably do better!
But I really like the look of your tag -- very professional and reassuring!Br. Jamie, osb
Thank you, Jamie. Starting to feel like I made the right choice.Steve Minnich0
If it has to be a metal tag something like this might work -
http://www.ebay.com/itm/Semi-Auto-Deboss-Metal-Label-Embosser-Dog-Tag-Stamping-Printer-Marking-Machine-/221675910287
3PSI gauge0 -
Nice!Steve Minnich0
Stephen,
I just started to label my new system with plastic engraved placards from a company I found online but also happen to be here in NJ - www.pipemarker.com.
I think they look very good and the cost was extremely doable.
Very nice. How are you attaching the sign in front of the copper pipe? And I can't see how the metal strip below the zone valves is attached? Very clean wire management!Steve Minnich0
Seton has the most comprehensive pipe label and markers available for tagging the pipes and valves:
http://www.seton.com/pipe-markers-valve-tags/pipe-markers.html?keycode=WS0121&campname=Pipe Markers||PC-08-PVM||NB||PPC||Pipe%20Markers||Pipe%20Labels||Tier%201&gclid=CPmfuduIhskCFQdsfgodJ1MCpQ2 -
