Piping and component labeling
Steve Minnich
Steve Minnich Member Posts: 2,868
edited November 2015 in THE MAIN WALL
Most of the commercial work we're picking up is requiring us to label just about everything. This is a picture of my first stab at it. I've looked at labeling devices specific to this purpose and the cost is like a grand. That's seems crazy to me. I'm open to any and all suggestions.
Steve Minnich
  • Rich_49
    Rich_49 Member Posts: 2,785
    I guess one just has to charge accordingly Stephen . I'll bet there is a spec of what type of material and chain the tags must be identified with also .
    Always something more every time we turn around .
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
    Steve Minnich
  • ratio
    ratio Member Posts: 4,172
    Looks nice. A lot of the jobs I've been on have specced brass tags with numbers on 'em, but those look more useful. Maybe mark them with normal position too?
    Steve Minnich
    Jamie Hall Member Posts: 26,760
    Very nice indeed. If they require metal, I've used the kind of soft copper tag sold for gardeners to label stuff with, and written on it with a stylus. Since my handwriting is atrocious, it's not that useful, but you'd probably do better!
    But I really like the look of your tag -- very professional and reassuring!
  • Steve Minnich
    Thank you, Jamie. Starting to feel like I made the right choice.
    Steve Minnich
  • BobC
    BobC Member Posts: 5,538
    3PSI gauge
  • Steve Minnich
    Nice!
    Steve Minnich
  • john p_2
    john p_2 Member Posts: 367
    Stephen,
    I just started to label my new system with plastic engraved placards from a company I found online but also happen to be here in NJ - www.pipemarker.com.
    I think they look very good and the cost was extremely doable.
  • Steve Minnich
    Very nice. How are you attaching the sign in front of the copper pipe? And I can't see how the metal strip below the zone valves is attached? Very clean wire management!
    Steve Minnich
  • jonny88
    jonny88 Member Posts: 1,139
    Funny I just saw this pic and was going to recommend that you saw it Stephen.Guess I better throw away my sharpie you guys are upping the ante
    Steve MinnichRobG
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Seton has the most comprehensive pipe label and markers available for tagging the pipes and valves:
    http://www.seton.com/pipe-markers-valve-tags/pipe-markers.html?keycode=WS0121&campname=Pipe Markers||PC-08-PVM||NB||PPC||Pipe%20Markers||Pipe%20Labels||Tier%201&gclid=CPmfuduIhskCFQdsfgodJ1MCpQ
    STEVEusaPASteve Minnich
  • john p_2
    I used electrical conduit clamps that I think electricians commonly call cowboys. Attached pcs.of 1/8" thick aluminum where I drilled a hole, countersunk it and attached w/a 1/4" screw with a nut. I will try and post a pic of them w/o the placard mounted to it.
    Steve Minnich
  • john p_2
    Here you go...
