Just when you thought you have seen everything....
Dan Foley
Dan Foley Member Posts: 1,268
You see this:
ZmanIronman
  • billtwocase
    billtwocase Member Posts: 2,384
    Isn't recycling good for the environment?
    RobG
    Steamhead Member Posts: 18,179
    You can't fix stupid!
    Consulting
  • Abracadabra
    Ah yes... that setup preheats the incoming combustion air providing higher efficiency!
  • ChrisJ
    ChrisJ Member Posts: 17,047
    edited October 2015
    Must be the same guy that does all of the vertical steam headers.
    Could be a EGR system to cool peak combustion temperatures and prevent knocking while running lean. :)
  • KC_Jones
    KC_Jones Member Posts: 5,902
    Maybe he used to be an auto mechanic. The old carbureted cars had a heat riser pipe coming up from the exhaust manifold to preheat the incoming air for warm up. He was just trying to replicate that. What's the problem? ;) lol
    2014 Weil Mclain EG-40
  • ChrisJ
    Most TBI systems had this as well as well as heated intake manifolds. The riser from the exhaust was usually called a "heat stove" from what I recall.
  • Ironman
    Ironman Member Posts: 7,842
    You only have to run one pipe outside when you do it that way! Saves on that precious commodity known as PVC.
    Dan, give us a pic of the inside of that thing.
    Bob Boan
  • Ironman
    What's the dryer hose carrying, natural gas?
    Bob Boan
    SWEIZmankcopp
