Refrigerant gauges
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
I've been happy with my Fieldpiece SMAN3's. Leak testing is so easy, superheat and subcooling at a glance. I had used analogs for decades, got tired of gages falling apart. I saw another tech using the SMAN3 a couple years ago and that was it.0
Hmm I've been very happy with my Testo 320 combustion analizer, so thats why I'm thinking of the 550s. Testo makes some quality equipment.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Great idea! And that's always been a source of irritation for me
Dave, if that tech had Testo, and I liked what saw, I may have gone that way. I do have a Testo combustion analyzer. 0 -
I've only done stuff on the side, my best is a set of Yellow Jacket Brute II's. Has anyone had those "fall apart" ?
http://www.amazon.com/Yellow-Jacket-46013-Charging-Manifold/dp/B004JRXK0M
For my monitor tops a gauge set is useless as all I ever use is a Yellowjacket micron gauge. I rarely use them but when I do I've never had any complaints about the Brute II's but they're far from cheap.
Here's the micron gauge I use.
http://www.amazon.com/Yellow-Jacket-69086-Hand-Held-Vacuum/dp/B0015A14QI/ref=sr_1_1?ie=UTF8&qid=1444047220&sr=8-1&keywords=Yellowjacket+Micron
I'm kind of a Yellowjacket fan I guess.
@Dave0176 I hope you haven't been only using a manifold set to vacuum systems with? The small vacuum range of the typical analog gauge is almost useless IMO.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
No Chris I actually bought the yellow jacket vacuum kit with the manifold to go on the vac pump with two 36" heavy duty black 3/8s hoses, and I use Yellow Jackets micron gauge too, kinda wish I would've bought the Blue Vac gauge though, which I understand their making the same gauge for yellow jacket now rebranded.ChrisJ said:I've only done stuff on the side, my best is a set of Yellow Jacket Brute II's. Has anyone had those "fall apart" ?
@Dave0176 I hope you haven't been only using a manifold set to vacuum systems with? The small vacuum range of the typical analog gauge is almost useless IMO.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
I do like some Field Piece stuff I got their digital manometer/static pressure tester that comes with the pressure sensor tester. Really nice tool. I also got a old school Yellow Jacket water manometer.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
The SMAN has the micron gauge built in, and temp clamps as well. One stop shopping.0
Whoa, that's pretty tricked out. Think I'll sit it out for a while and see how that goes. Heck, after 24 years of analog, I'm light years ahead with the SMAN
I'm not sure about the digital gauges. I keep going back and forth on getting a pair, but I keep hearing guys having problems with them. Just don't want to shell out that kind of money.0
I've got the SMAN4 & I think it's great. The only complaint I have is about the k-type clamps - they don't last very long. Fortunately, any k-type clamp will work. I like the UEIs, but the cable is short. I'm also experimenting with leaving a k-type permanently attached to systems. We'll see how long they last.
The latest edition of the SMAN4 shows all the numbers on the screen at once, sc, sh, saturation & line temps, the works. Another feature is that it will communicate wirelessly with a number of other Fieldpiece instruments & give you a live target superheat. Fun!
That's part of the problem is clamps. What size copper do they go up to? I'm assuming the make straps to for the bigger tonnage equipment?0
I think the Testo 570s have the integrated micron gauge, but these gauges go for about $500 bucks.Bob Bona said:The SMAN has the micron gauge built in, and temp clamps as well. One stop shopping.
I'm surprised no one has any experience with the Testos, did I mention I love my 320 combustion analyzer.......lolDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
@njtommy, they claim IIRC 1-3/8, but one of the problems I've run into is that the spring is strong enough to stress-fracture the hinge point after a year of light usage. The other thing I've run into is the mini connector becoming intermittent internally, although that might have been caused by my little buddy putting it back into it's storage bag without unplugging them - only once though! I replaced the connector a few days ago & it seems to be working fine now.
WRT the UEI clamps, they have a little metal strain relief on the connector, makes me think they're built a lot stouter compared to the molded connectors on the Fieldpiece. They also have one that has a Velcro attachment that fits up to something like 2-5/8. The cords are short though. I picked up some female connectors, I'm going to try some extension cables.
I'm gonna plug the four-port manifolds too. I sucked down a warehouse cooler with a 140 lb receiver to under 500 microns in just a few hours using a Imperial four port manifold & a 1/2" vacuum house attached to my 7 cfm vac. All three of the other hoses were nippled onto the system - I had to go on both sides of the head pressure control valve, so I was going to end up with a four port anyway. It's analog, in fact I just replaced the gauges on it. I'm pretty pleased with that one too. I use the charging port to attach my micron gauge when I'm working on splits. You just gotta shut the vac port to get a real micron reading.0
Nice. The afore mentored cooler, came with a brass shaving inside the suction king valve. For free! The supplier couldn't get a factory replacement in a timely manner, so I had to change the flange out too - 2-5/8. Took a 32 tip on a B tank, & I had to get pissed off too before it came off!
I don't leave my digitals overnight either, but I let my guys use them from time to time.
You know pretty darn quick if you have a leak with the digitals, vs the analog
You know pretty darn quick on an SO2 unit in the complete dark without gauges.Bob Bona said:You know pretty darn quick if you have a leak with the digitals, vs the analog
2 -
Nice big Copeland, I'm used to the big 6 cylinder Carlyle's, in Carrier A/Cs.njtommy said:I have 2 sets of 4 port analog gauges and absolutely love them, but I leave them on units overnight a lot to on the pump. I wouldn't leave a set a digital gauges on over night. Lol.
Today's job two copeland swap outsDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Yes sir, speaking of which, I'm working on a 30 ton Carrier split condenser with a Carlyle 06E, there is some cooling and I found the compressor for what ever reason to keep cycling on the unloader, my head was only 225, but then it cyles down and head drops to like 175?? Also the second condenser fan wasn't running but givin the cool temps its not supposed to run.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Is it electronic unloader or mechanical?0
This is a mechanical unloader.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Maybe its weak??DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Is set by your suction pressure. I would recheck your charge as by there chargeing chart and recheck you suction pressure and super heat. This time of year your going to cycle a bit between loaded and unloaded. Is this on a VAV system to?0
You can adjuste them but you need to look at the total system.
What's your return air
Supply air
Super heat
subcooling
What is set point by the controller or controls? If it's a VAV system it's normally 55 supply air set point. Maybe 60 in the winter.
Does this also have Hot gas bypass?0 -
No VAV just a regular single speed AHU. I did notice a lot of oil around the liquid line solenoid valves. Can't seem to find any leaks though.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
