Steam replacment coming up
ChrisJ, you might be right. I don't know what the operating characteristics of the boiler are when derated by manifold pressure. I know that the LGB series is available with a 2-stage valve and I have been told that it remains very efficient on low fire. So, for the EG, I don't know. Did you do any efficiency testing on yours in an underfire operation? I was told by one of the pros that my old Pennco, which was firing at a reduced rate would have a high amount of excess air and a significant loss of efficiency. The huge improvement when the boiler was replaced seemed to substantiate that.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
No testing on mine in that regard as I don't plan in underfiring it. When it gets cooler out Jstar will be coming out to set things out so maybe he'll be interesting in trying that, I don't know.Dave in QCA said:ChrisJ, you might be right. I don't know what the operating characteristics of the boiler are when derated by manifold pressure. I know that the LGB series is available with a 2-stage valve and I have been told that it remains very efficient on low fire. So, for the EG, I don't know. Did you do any efficiency testing on yours in an underfire operation? I was told by one of the pros that my old Pennco, which was firing at a reduced rate would have a high amount of excess air and a significant loss of efficiency. The huge improvement when the boiler was replaced seemed to substantiate that.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Final pics of installDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
What's up with that connection into the chimney?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
The chimney was just lined, thats the bricks just shoved back into place, it all needs to be cemented. The boiler is fully connected to the flue.ChrisJ said:What's up with that connection into the chimney?
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
