Tight install
Just finished this one today. Think I need to lose a few pounds after being in this closet for a couple of days.
kcoppRobGSteve MinnichIronmanBob Bona_4
  • bob_46
    bob_46 Member Posts: 813
    It takes a real mechanic to do a neat well laid out job in a tight space. Kudos
    Aaron_in_Maine
    hot_rod Member Posts: 26,575
    Nice shoehorn work! thanks for the Caleffi use.
    Is that a custom heat shield inside the door?
    Aaron_in_Maine
  • SWEI
    SWEI Member Posts: 7,348
    Nice work, and nice touch having two doors for access.
    Aaron_in_Maine
  • NYplumber
    NYplumber Member Posts: 503
    Nice work. Small places are hard to work in, but when all works out, its very rewarding.
    :NYplumber:
    Aaron_in_Maine
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Very nice!!
    Aaron_in_MaineZman
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Haven't seen anything that sweet since Ron Jr. Thanks for sharing!
    Retired and loving it.
  • R Mannino
    R Mannino Member Posts: 441
    Sweet! Where'd you hide the indirect?
  • Aaron_in_Maine
    Aaron_in_Maine Member Posts: 315
    Yes that heat shield is from the old boiler. The customer is going to do a new one that goes 3/4 of the way across the door. I like the propress zone valves and when you get the 5 year warranty when using the zone control its a no brainer.
    @hot rod
  • Aaron_in_Maine
    If you look at the pic from the back of the boiler its tucked way in the back of the closet.
  • STEVEusaPA
    Very nice indeed. I love how nothing is directly above the burner. Like many of us....if I had a dollar for every time I stood up from a kneeling position at the burner and cracked my head...sometimes more than once on the same call...
  • ChrisJ
    ChrisJ Member Posts: 17,067
    What's the actual name of the thermal switch mounted above the boiler?
    I wouldn't mind adding that to my system even though it's not required here.
  • Marz
    Marz Member Posts: 90
    @ChrisJ That would be an electrical Firomatic. Cuts power at 165 degrees if I remember right
    ChrisJ
  • Robert O'Brien
    To the best of my knowledge, thermal switches are required in MA?
  • ChrisJ
    How dare you!
    Take that back!!
    I'd never live in MA! :D
    Robert O'Brien
