Tight install
Aaron_in_Maine
Member Posts: 315
Very nice!!
To learn more about this professional, click here to visit their ad in Find A Contractor.2 -
Haven't seen anything that sweet since Ron Jr. Thanks for sharing!Retired and loving it.0
Sweet! Where'd you hide the indirect?0
Yes that heat shield is from the old boiler. The customer is going to do a new one that goes 3/4 of the way across the door. I like the propress zone valves and when you get the 5 year warranty when using the zone control its a no brainer.
@hot rodThere was an error rendering this rich post.
If you look at the pic from the back of the boiler its tucked way in the back of the closet.
Very nice indeed. I love how nothing is directly above the burner. Like many of us....if I had a dollar for every time I stood up from a kneeling position at the burner and cracked my head...sometimes more than once on the same call...
What's the actual name of the thermal switch mounted above the boiler?
I wouldn't mind adding that to my system even though it's not required here.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
To the best of my knowledge, thermal switches are required in MA?ChrisJ said:What's the actual name of the thermal switch mounted above the boiler?
I wouldn't mind adding that to my system even though it's not required here.To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Take that back!!
I'd never live in MA!Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
