EI spark ignition didn't want to light?
Since then, it's lit fine ever since. Is it normal for the pilot to seep all of it's gas out or something over a long period and need to purge like this, or do I have another issue?
My first assumption was a spider caused it and I guess it cleaned it self out but now I'm wondering if I should go through the pain to pull the burner tray out and give things an inspection.
Boiler is a Weil-Mclain EG series steamer from 2011.
It's rejecting the barometric conversion.3
Maybe dust on the flame sensor had to be burned off. After sitting a week my truck won't start on first try either.
Pilot & line has no gas in it except during firing.
You could have had air in your gas line.
Any number of little things..... and we are all glad for continuous or at least 3 times retry for ignition.
Try it again every day and see if it stumbles again.1 -
How could there be air in the line though? I didn't work on any piping.
WAG on my part is that some "air" might come with NG?? Being heavier than NG could settle down your pipe drop to boiler. Do you have NG water heater? Did you check the drip pipe on the bottom of NG drop? Has the utility done any work on UG NG lately?
More to worry about, air will turn the meter just like NG.
Don't think anything was done and yes to water heater and dryer and Weber grill
I found out this week the line coming in from the road runs at 50psi though which blows my mind
So the single regulator at the meter drops you from 50PSI to your 4 oz? No other regs in system inside?0
To be specific, 50 PSI to 6" W.C.JUGHNE said:So the single regulator at the meter drops you from 50PSI to your 4 oz? No other regs in system inside?
This is what a tech from the gas company told me on Wednesday or Thursday when he was out here.
It's fed by a 1/2" plastic line they ran to the house in October 2011.
Why do you ask?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
By the way, can a CGV suck air in if you shut off the input side and the area cools a decent amount? Not sure if the regulator has a vent or not and what can happen
I had the gas shut off to the boiler for a week or so while I switched over to the barometric and the basement cooled down quite a bit due to it cooling off at side and I had a minor dehumidifier situation. This probably resulted in a good 10-15 degree drop.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Professional curiosity, we have 10-15 PSI in the alley with meter/reg there. Then UG 1 1/4" steel coated/wrapped service pipe to house with cathode protection on entire system. UG service runs are 50 to 75' @ 4 ozs/7" WC.
We still call before digging, a shovel will not cut the steel pipe but could cut the coating which should be repaired before covering.
None of this would answer your question.......however your CGV question is for Tim.1 -
Ah,JUGHNE said:Professional curiosity, we have 10-15 PSI in the alley with meter/reg there. Then UG 1 1/4" steel coated/wrapped service pipe to house with cathode protection on entire system. UG service runs are 50 to 75' @ 4 ozs/7" WC.
Maybe it's because I'm on a state highway, no alley here.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
youse guys gotta stop this before I wet myself. The gas in the line from the gas valve to the pilot was lost during the summer by diffusion. When you turned it on the line had to bleed itself before it would light. To be specific it diffused through the .018" hole in the pilot orifice.
That's what I assumed happened, but I really wasn't sure if it made sense.bob said:youse guys gotta stop this before I wet myself. The gas in the line from the gas valve to the pilot was lost during the summer by diffusion. When you turned it on the line had to bleed itself before it would light. To be specific it diffused through the .018" hole in the pilot orifice.
So basically, it's 100% normal after sitting all summer.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Something like this happens all the time. It is just that usually the homeowner isn't there to observe it. Try it a few times before winter really gets here.
Hydrogen molecules can get out of a steel pipe over time via diffusion through the pipe walls. This is why converting everything to hydrogen would be nearly impossible due to our steel distribution systems. If we decide to "Go Hydrogen", we are going to have to dig up all the old steel and replace it with fiberglass piping. which can hold hydrogen.
As others have noted, it usually isn't usually perceived as a problem and will catch by the third try before locking out.
ME2
- 15.8K Strictly Steam
