Trap test
HEATON
Member Posts: 118
WHat is the best way , short of dismantling , the radiator traps on two pipe steam systems?
When the boiler is running... a) the radiator should get hot. If it doesn't, the trap is failed closed (or, of course, the inlet valve is closed...). b) when the radiator is pretty well hot all across, the outlet pipe (below the trap) could be warm -- perhaps quite warm -- but not steam hot. Best to check with an IR thermometer, but can also do it by hand. If the pipe is steam hot, the trap is failed closed.Br. Jamie, osb
Yup. Guess I'm getting old!Br. Jamie, osb
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
