Trap test
HEATON
HEATON Member Posts: 118
WHat is the best way , short of dismantling , the radiator traps on two pipe steam systems?
    Jamie Hall Member Posts: 26,005
    When the boiler is running... a) the radiator should get hot. If it doesn't, the trap is failed closed (or, of course, the inlet valve is closed...). b) when the radiator is pretty well hot all across, the outlet pipe (below the trap) could be warm -- perhaps quite warm -- but not steam hot. Best to check with an IR thermometer, but can also do it by hand. If the pipe is steam hot, the trap is failed closed.
  • Abracadabra
    Abracadabra Member Posts: 1,949
    .... If the pipe is steam hot, the trap is failed closed.
    Think you mean "open" :)
    Yup. Guess I'm getting old!
