Is there a heating expert Richard McGrath on here?
JoshJ
Member Posts: 1
Hey, I just looked at your response to a question I asked on a green building blog, and I just wanted to ask how much it would cost me to have you don an expert design of a radiant heating system for my next house (I already sold the one referred to in the post--people love in-floor heat. Also, the house had none of the problems you predicted. Like I said, the temperature is within three degrees in all rooms in the house. And the boiler is working just fine. So actually, every single thing you said would happen has not happened.)
-2
Sounds like you did not like some advise you were given on one site so you figured you would go to another for a bit of bashing?
Glad to here you system works so well, even a broken clock is right twice a day.
Now run along....."If you can't explain it simply, you don't understand it well enough"
Albert Einstein7 -
Oh , you mean this one .
http://www.greenbuildingadvisor.com/community/forum/mechanicals/39775/why-it-so-trendy-hate-radiant-floor-heat
Glad everything worked out for you . So why'd you sell it ? I'll bet the boiler is working real good , for about 1 to 2 minutes at a time . I sure do wish I could achieve 3 degree temp variations from room to room . Good thing for you is that you sold it and when it becomes a problem for the unsuspecting purchaser we'll be here to help . My contact info is below .
Anyway , good luck to you .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38333 -
Thats exactly the thread I thought of when I read this on GBA .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Looks like it is this guy,
http://www.sisubuilders.com/about.html
The system he installed looks like a perfect fit for the work he is doing..."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Should of installed a buffer tank and zoned every single room in the house. If that boiler isn't short cycling with that design would only be because you have such high DT a crossed the supply and return. That boiler has a pretty high minimal firing rate of 18,000 btus. Its not hard to do the math and see that if you where on a traditional design radiant system that boiler would short cycle like crazy and luckily Navien has a built in time delay to help prevent short cycling.0
I am wondering how he got his statistical data when he just built and sold the house? It takes most people at least a couple of seasons. Even a forced air system properly designed can keep a home at less than a three degree temperature swing. You don't get what you don't pat for. If the OP is still lurking I would love to see photos of the install.2
- 120 Geothermal
