no hot water with a side arm
hickory_hollow
Member Posts: 5
built a new house 1 year ago put in a 4400 woodmaster stove works great but I have had really high power bills since day one $200 + every month. started trouble shooting with a clamp on amp meter found my hot water heater was running even though I have it connected to my wood stove.... so I shut the breaker off and only get warm water now meaning my side arm is not doing what its meant to do. my wood stove runs at 160 to 170 degrees and the side arm is extremely hot but no hot water. I have attached a picture of how the plumbing is done on the hot water heater. please help my wife misses her hot water. we have been turning the hot water heater on a hour or 2 before showers but we shouldn't have to do that.
Can you post an actual pic or two of the piping and side arm?
Is the re-circ pump running continuously?Bob Boan
yes the re-circ pump runs all day and off at night its on a timer ill work on a pic or two.0
new pictures0
Ironman can you see the pic?0
It won't work. It needs a pump. It won't circulate that way.
He/you shows a line from the HX entering into the top of the tank, separately from the hot and cold. There's only three holes in the top of a water heater tank. Maybe four if you count the anode rod hole. Did you remove the temperature pressure relief valve and enter there? You CAN'T!!! do that.
You just can't.0 -
Is there a rating for that sidearm? In terms of BTU per hour? And -- how much flow from the hot water tank actually goes through the sidearm? If you are depending on gravity circulation, it isn't going to be much. You need to take a serious look at how many BTU/hour that sidearm can deliver, and your water flow through it, to figure out whether or not it can deliver the amount of hot water you want.Br. Jamie, osb
Close the summer/winter ball valve so that it is open 1/4 turn. If you have one, and you should, or you will experience exactly what you are having issues with. Could not see pics
- 123 Chimneys & Flues
