Staying safe
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,634
In weather like we're having, what advice would you give homeowers about their heating systems that could save their lives?
Retired and loving it.
MikeL_2
  • Abracadabra
    Check that sidewall vents (furnance/hot water/dryer) have not been blocked by snow.
    Mark EathertonJean-David Beyer
  • BobC
    BobC Member Posts: 5,522
    Make sure any outside vents are clear, some areas have seen very heavy drifting of snow.
    Also make sure all smoke and CO detectors are working.
    Bob
    3PSI gauge
    Gordy
    Jamie Hall Member Posts: 26,036
    Not just sidewall -- in some structures the roof drifts can get to four or five feet (or more!), and the roof needs to be checked, too.
    Also -- and it sounds silly -- make sure there is enough fuel in the tank, if you heat with oil or LP.
    If you feel a need for auxiliary heat -- don't ever use a ventless LP appliance without CO detectors, and even then not in a bedroom (some codes prohibit them entirely). And keep any auxiliary heater well away from anything even remotely flammable.
    GordyRobG
  • BobC
    edited February 2015
    One thing I forgot - make sure there is a path shoveled to the oil tank fill. You don't want to give an old tired oil delivery man any excuses same thing holds if you use propane.
    Bob
    3PSI gauge
    GordyRobG
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,872
    Keep an eye out on your NEIGHBORS vents, especially the elderly and disabled. And as others have stated, make sure you have a working CO and smoke detector near the sleeping areas of the home.
    ME
    GordySWEIRobG
  • Dave0176
    Dave0176 Member Posts: 1,178
    Funny, got a no heat call today 95% warm air furnace , turned out to a frozen exhaust vent.
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    Specializing in Steam Heating, Serving the residents of New Jersey
    https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
    https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,264
    Lets not forget the electric space heaters and lamp cords. I caught one of my customers with a 1200 watt space heater running with a 16 gauge extension cord. I made them go buy a heavier cord.
    A 16 gauge extension cord that has any length will not carry the load of a 1200 watt heater. The cord will heat up and start a fire.
    Please use heavy duty 14 gauge or 12 gauge cords if you must use a space heater. Make sure you plug it into a receptacle where it fits tightly. If the socket feels loose, plug it in somewhere else till you get the receptacle replaced.
    GordySWEIRobG
  • Gordy
    Gordy Member Posts: 9,546
    Look out for each other along with what is mentioned above.
    jonny88RobG
  • DanHolohan
    Great advice, guys. All of this is so important for the homeowners to know. I'm going to add it to the Blog section so it sticks around. If you want to add anything else, please do. Thanks for saving lives!
  • icesailor
    icesailor Member Posts: 7,260
    Don't turn the thermostats to the lowest settings in unused spaces. The pipes will freeze during the off period. Don't use setback thermostats. Set them together for a reasonable temperature.
    If you lower an inside thermostat by 20 degrees to save money, and the system was designed for zero, and can barely make it, lowering the thermostat by 20 degrees is the same as dropping the outside air temperature to -20 degrees. If it is blowing 40+ MPH, that makes the infiltration factors go way up.
  • MikeL_2
    MikeL_2 Member Posts: 531
    In the event of a power outage, do not use your outdoor grille, or generator in the garage, and, make sure fire hydrants are shoveled out. Please keep ladders, bodies, and, roof rakes away from power lines...........
  • DanHolohan
    Here's what we have. If you'd like to add to it, let me know. Thanks: https://heatinghelp.com/blog/staying-safe-when-the-weather-is-snowy?stage=Stage
    Mark Eatherton
  • Jean-David Beyer
    If they have not had their annual inspection and maintenance done yet, do it as soon as the service technician can get it done. Why wait until New Year's eve to do some maintenance?
