Gas pilot fuel usage...
kcopp
Member Posts: 4,646
in Gas Heating
Does anyone have an idea about how much fuel a gas pilot uses?
I realize a that it depends on the pilot. But as a percentage how much of you gas use is your pilot use? approx.?
I have heard the number 10% thrown around.
I also realize that a pilot burning has some advantages...especially in a damp basement.
ty,kcopp
ty,kcopp
Going by this it appears to be about 2%.
Of course, after reading what I did about AFUE readings I don't know how useful these numbers are.
A typical pilot is around 1000 btus. That would be 8,760,000 btus for 365 days. Assuming heating usage is 55 to 60 million btus a pilot would be 14%-15%. During the heating season pilots
are heating the water on a boiler and water in a water heater all year long. Except in the summer on a heating appliance, I would think pilots waste very little energy during the winter.1 -
I have a chart I use that gives different orifice sizes and the gas pressure used either 3.5" W.C. or7" W.C. Because heating gas valves do not regulate pilot gas but the pilot is on line pressure you would use the 7" figure that gives you use per day times 365 and then multiply cubic feet times your local cost per cubic foot.
To give it a dollar value I usually find it costs about $100 to $150 per year depending on the cost of gas.2
- 116 Geothermal
- 15.8K Strictly Steam
