needing 100,000 btu 90+ boiler with 2" vent
Jim_115
Member Posts: 4
I'm needing to replace a Hydro Pluse boiler with 2" venting and it would be very difficult to install 3" venting.
Is there a 90+ boiler out there that uses 2" venting instead of 3"? It would have about 50ft total of intake and exhaust piping.
Thanks
Thanks
Utica wall hung, or the naviEn combo.0
Thanks guys! Looks like either one would work I'll have to get the exact measurement to know for sure.0 -
I think there was a time when you could use both 2" as exhaust, with combustion air from inside. Didn't the HTP Munchkin offer that venting option? Had to be solid core PVC, of course.Bob "hot rod" Rohr
Are you sure that you need a 100K boiler? Has a heatloss of the structure been done? In the early days of high efficiency the 100k pulse was one of a very few HE boilers out there. Chances are it is oversized.0
- 120 Geothermal
