Boiler cycles even when thermostat equal to room temp
rrwitherspoon
Member Posts: 104
Is your Tstat set for 1CPH? This is a recurring problem with the newer Tstats, but easily fixed. Also, the digital Tstat only register integers +/_ 1 deg so it could really be lower than it reads.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF-1 -
How do you set thermostat for 1 CPH
My thermostat jusy gives me options for day of week , time and temp in degrees0 -
What is the make & model of your Tstat?Two-pipe Trane vaporvacuum system; 1466 edr
Most stats, especially Honeywell and Emerson, won't deviate from the set temp unless the house really warms up or cools down. A few brands will wait til the display shows 69 before turning the heat on and may run it til 71 appears.0
White Rodgers programmable thermostat0
Without a model number it's hard to look up the install manual. If you still have that it should give directions for setting the CPH to 1 or steam. You could try googling it, also.Two-pipe Trane vaporvacuum system; 1466 edr
Where would I find model number? The thermostat was installed in 20050
Ok0
1F80-361 white rodgers thermostat 5-1-10
Do you have the manual? For steam it needs to be programmed to SL. You can find the manual online.0
SL option never comes up as a choice
Only day of week and time0 -
- 117 Geothermal
