piping
officer1
Member Posts: 1
hi was just wondering in my house there is a two-pipe steam system my guess it was put in around 1918 do you think the piping should be replaced do to its age and the associated corrosion with steam heat or would it still be ok .
No
Unless it's leaking out of the pipe or badly corroded.
Have some pics0 -
Steam
will keep the piping nice and clean and corrosion free. The only place you may have to worry is on wet returns, which should be inspected from time to time. Even there, they are much more likely to corrode from the outside in, rather than the other way.Br. Jamie, osb
Chemistry
Depends on the chemistry of the returning condensate. So long as it's alkaline, above 7 on the pH scale, you should be fine. If it's acid, below 7, you can expect all kinds of problems with iron and steel piping.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
two pipe in 1918?
Was this one of the first? Where is it?0 -
Longevity of 2-pipe system
The pipes will likely be fine, although you may need some trap repair.--NBC0
