piping
officer1
officer1 Member Posts: 1
hi was just wondering in my house there is a two-pipe steam system  my guess it was put in around 1918 do you think the piping should be replaced  do to its age and the associated corrosion with steam heat or would it still be ok .
  • Snowmelt
    Snowmelt Member Posts: 1,457
    No
    Unless it's leaking out of the pipe or badly corroded.
    Have some pics
    Jamie Hall Member Posts: 27,243
    Steam
    will keep the piping nice and clean and corrosion free.  The only place you may have to worry is on wet returns, which should be inspected from time to time.  Even there, they are much more likely to corrode from the outside in, rather than the other way.
  • Pumpguy
    Pumpguy Member Posts: 795
    Chemistry
    Depends on the chemistry of the returning condensate.  So long as it's alkaline, above 7 on the pH scale, you should be fine.  If it's acid, below 7, you can expect all kinds of problems with iron and steel piping.
  • jumper
    jumper Member Posts: 2,526
    two pipe in 1918?
    Was this one of the first? Where is it?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Longevity of 2-pipe system
    The pipes will likely be fine, although you may need some trap repair.--NBC
