Paragon EC403 manual?
ratio
Member Posts: 4,216
Anyone know where I can download the manual for a Paragon EC403 "Heating/Cooling Energy Optimizer"? Google hasn't been able to help me, the closest I've been able to come is an EC404 w/ manual on a certain auction site (for more than I'd like to pay), and paragoncontrols.com doesn't seem to know about anything other than currently-produced airflow controls.
Thanks for any help!
ratio
ratio
It might help to post a picture.
It may be another product rebranded
Albert Einstein0 -
pics of similar model
There is an identical-looking item at http://www.ebay.com/itm/Paragon-EC404-Heating-and-Cooling-Energy-Optimizer-w-Sensors-and-Manual-/221350665847?pt=LH_DefaultDomain_0&hash=item3389871e77, save that my model is EC403 rather than EC40. It's a good likeness of the keypad & display, but I can't say for certain if the term strip/relays are identical. I'll try and get more pics.
ratio0 -
Found! manual for Paragon EC403
I found a xerox of the manual stuffed away in the boiler room! I've attached a crummy scan of it in case anyone else is looking for one.
ratio0 -
second try...
Maybe I've attached it this time...
ratio0 -
Manual for Paragon EC403
Ok, couldn't get the attachment to work, so https://dl.dropboxusercontent.com/u/37752502/Paragon_EC403.pdf
ratio0
- 117 Geothermal
