what is the best wood fired boiler
greenhead_2
Member Posts: 13
Im looking to supplement my propane boiler with wood is there one brand better than others. maybe a smaller profile and lower cost or a fire place that heats hot water. help
Less boiler more storage
The key to wood is energy storage. They are most efficient at high fire and you really cant turn one off. The other truth is that many manufactures are incompetent system designers.
There are tons of "boiler install goes bad" posts on here.
Check out the attached file as a design starting point.
Albert Einstein0 -
What Type?
Indoor or outdoor? Pressurized or non pressurized? Conventional or gasified?
There's no pat answer without knowing what your looking for, how much you wanna spend, what your connecting it to and other factors.
Carefully study the Idronics 10 issue that Zman attached and you'll be much better equipped to make decisions and plan what you need.Bob Boan
Got wood?
I really like this one, saw it at the NEFI show at Foxboro.
http://www.qhtinc.com/biasi-products/solid-fuel-boilers/pirowood/0 -
Wood
This one looks real nice too.
http://www.buderus.us/products/woodheating/g201wood-firedboiler.html
Unless you have a good source for wood a lot of time and energy. I don't think it is all that cheap. You have to buy the stove, the chainsaw, the 4 wheel drive truck, etc.. You have to devote time to hauling, splitting, and stacking the wood. I would rather hustle some overtime a couple of weekends and use the money to buy oil and spend the weekends at car events, but that's just me.
I have a wood stove. I use it when it is real cold or when the power goes out. Simple. Wood boilers are a little more fussy .0 -
Walk quietly and carry a big stick...
The EPA has banned about 80% of the wood burners on the market. My limited understanding is that ONLY gasifiers are allowed.
Google EPA bans wood burning appliances and see what pops up. I suspect there will be some real FIRE sales in the near future…
More great protect us from ourselves rulings to come….
ME0 -
Not available any longer
Bill,
Buderus has pulled that boiler from the U.S. market. It's still available in Europe, though.
I wonder if it's because of the EPA non-sense? Kinda strange isn't it: you can burn wood in a fireplace and make all the smoke you want, but throw those same logs into an OWB and big brother has to get involved. It's all about control, not concern for our well-being.Bob Boan
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
