steam help
brian75
Member Posts: 1
I have a steam boiler im replacing there is no return main. The feed comes off the top and runs to the radiators there is a t that drops off the feed to the boiler drain and the cold water ties in with it there is no hartford loop. They have replaced one boiler and piped it this sam
. Way what should i do
Repost
I would repost this one time in the strictly steam section. Pictures would help!"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Counter flow
Your description is a little fuzzy, but it sounds like a counter flow system.
As Zman suggested, post this with some pics on the steam section.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
