How's this for an Old-Timer?
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,686
I visited this one last week. It's nearly 100 years old and still running.
Retired and loving it.
    Steamhead Member Posts: 18,203
    I still see these once in a while
    though most have had their gas and limit controls upgraded. Looks like that one is pretty much original! What kind of system is it hooked up to- one-pipe? Vapor?
    Consulting
    pecmsg Member Posts: 6,770
    Boiler
    Dan
    After all these years you’re finally changing your boiler!
    Now that’s steam piping
  • DanHolohan
    It's a two-pipe Dunham system
    Everything is original and in good working order. You would have loved it.
  • DanHolohan
    Wish it was mine.
    It was all very steam-punky in this place. Lots of fun.
  • Char80
    Char80 Member Posts: 4
    Looking good..
    Amazing that it still works well too. Just goes the show that the old cliche of they don't make things like they used to has a sound basis.
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Seen a few of these in
    my day. The training at the gas company in the 1960's still included these gas control systems. We eventually changed most of these over to Powerpile Systems.
  • SWEI
    SWEI Member Posts: 7,348
    Mechanical gas controls
    Had to go back and look at the first photo again after reading Tim's comment.
    Is that just an on/off control, or does it modulate on pressure?
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    I know it has worked for 100 years
    but I had to comment that they never used 6" nipples between the elbow and the header as we insist on today.
    cell # 413-841-6726
  • OSCO1923
    OSCO1923 Member Posts: 5
    A good boiler should last 100 years
    This is living proof!!!
  • jumper
    jumper Member Posts: 2,501
    hindsight
    Instead of replacing old boiler there was the option of adding economizers to improve efficiency. Old boiler can outlast its replacements.
  • Economies?
    What form do these take? Maybe it would be a coil of water in the flue.--NBC
  • jumper
    economizers
    In the seventies Fulton offered different models. Governments and GasInstitute helped pay to instal and test. Water tube absolutely required a flow switch to shut down boiler when circulation failed. There was also a fire tube which was supposed to be more robust. In cold weather the issue was what to do with that energy.
