Gravity hot water heat
I need to brush up on converting a gravity
Gas fired heating system. Which one of Dan's
Books should I read too refresh my memory.
There are two supply's and two returns coming
Off the existing boiler. One stat in the house.
Also have to add a separate baseboard heat zone to four season room.
  • Zman
    Zman Member Posts: 7,611
    Classic Hydronics
    I think classic hydronics has the most info on conversions.
    One of the gurus on here posted some circulator sizing info in resources. I can't seem to find it right now.
    Carl
    Albert Einstein
  • Zman
    Albert Einstein
  • radiantking
    radiantking Member Posts: 7
    Gravity
    Thank you Carl, I have that book. And will read.
    This is a closed system, with expansion tank in the basement
    Home owner has told me that radiators on the second floor have stopped
    Heating several years back. I think I will need to figure out what is causing this
    Prior to installing new system. Radiators are piped at top and bottom on same side
    With vent at opposite side. Any thoughts would be appreciated.
    Bill
  • jumper
    jumper Member Posts: 2,501
    look in attic
    You may be surprised. Expansion tank in basement was probably added along with gas burner.
