Gravity hot water heat
radiantking
Member Posts: 7
I need to brush up on converting a gravity
Gas fired heating system. Which one of Dan's
Books should I read too refresh my memory.
There are two supply's and two returns coming
Off the existing boiler. One stat in the house.
Also have to add a separate baseboard heat zone to four season room.
Classic Hydronics
I think classic hydronics has the most info on conversions.
One of the gurus on here posted some circulator sizing info in resources. I can't seem to find it right now.
Albert Einstein0 -
Here it is...
http://www.heatinghelp.com/article/343/Circulators/238/Sizing-Circulators-for-Hot-Water-Heating-Systems
This whole section is super useful
http://www.heatinghelp.com/article-categories/332/Gravity-Hot-Water-Heating
You should still buy the book, it is very interesting.
Albert Einstein0 -
Gravity
Thank you Carl, I have that book. And will read.
This is a closed system, with expansion tank in the basement
Home owner has told me that radiators on the second floor have stopped
Heating several years back. I think I will need to figure out what is causing this
Prior to installing new system. Radiators are piped at top and bottom on same side
With vent at opposite side. Any thoughts would be appreciated.
Bill0 -
look in attic
You may be surprised. Expansion tank in basement was probably added along with gas burner.0
- 114 Geothermal
