T-Stat
KCA_2
KCA_2 Member Posts: 308
Hi Guys...
   Who has a T-Stat that goes below 50degF?   Even 40degF maybe...
  Thanks....
:-) Ken
  • Dave H_2
    Dave H_2 Member Posts: 619
    Setpoint Controller
    You can use the tekmar 150 setpoint controller. Use the slab sensor not in the slab, but in a wall box or such. Setpoint Operation: -40 to 239+F
    Dave H.
    Dave Holdorf
    Taco, Inc
    hot_rod Member Posts: 26,121
    edited May 2013
    Uponor
    the old A3030101 if it is still around. Nice for garages 38-98F freeze protection 38-39F I think you can set a high and low limit also.
    www.uponorpro.com/~/media/Files/Technical%20Documents/Specifications%20and%20Submittals/NRadiant%20Heating/Zoning%20Controls/A303010x_Thermostat_03%2005%202009.aspx?sc_lang=en
  • cattledog
    cattledog Member Posts: 60
    Tekmar 150
    Good call Dave. I use a Tekmar 150 and with a set point of 34 F to control a heater which keeps a greenhouse just above freezing. I have the slab sensor hanging in the air among some plants.
  • Dave H_2
    Setpoint Controller
    I have also used this in car wash "ice prevention" projects. Its not for snowmelt (you wouldn't get your car washed when snowing!!) But the water dripping off the cars can freeze the entrance ramp.
    Dave H.
    Dave Holdorf
    Taco, Inc
    Jamie Hall Member Posts: 26,638
    There used to be
    a version of the good old Honeywell T87 which went down that far.  Don't know if it's still available...
  • KCA_2
    Thank you
    All for the information...  They all are available and I'll order one..
    :-) Ken
  • Zman
    Zman Member Posts: 7,611
    Uphonor
    The other nice thing about the uponor is that you can lock out the high and low. Perfect for places where people meddle with t-stats.
    Carl
    Albert Einstein
