Pressuretrol setting question ......
Ron Jr._3
Ron Jr._3 Member Posts: 605
What happens if you have a pressuretrol with the " diff " setting higher than the main setting , and the diff is subtractive ?
    Steamhead Member Posts: 18,483
    Haven't tried this
    but I'd think it would shut off on pressure, and not turn back on when the pressure drops.
    Consulting
  • Ron Jr._3
    Gonna have to try it
    next time I go back to do a skim and purge on a system . My guess is it would cut back in at 0 psi , but that;s just a guess ..............
    Jamie Hall Member Posts: 27,346
    Steamhead's right...
    I've found that out the hard way.
  • SWEI
    SWEI Member Posts: 7,342
    making it into
    a kind of manual reset high limit control?
    Yeah,
    but that wasn't the idea at the time... !
