Pressuretrol setting question ......
Ron Jr._3
Member Posts: 605
What happens if you have a pressuretrol with the " diff " setting higher than the main setting , and the diff is subtractive ?
Haven't tried this
but I'd think it would shut off on pressure, and not turn back on when the pressure drops.All Steamed Up, Inc.
Consulting0 -
Gonna have to try it
next time I go back to do a skim and purge on a system . My guess is it would cut back in at 0 psi , but that;s just a guess ..............0 -
Steamhead's right...
I've found that out the hard way.Br. Jamie, osb
making it into
a kind of manual reset high limit control?0 -
Yeah,
but that wasn't the idea at the time... !Br. Jamie, osb
- 119 Geothermal
- 394 Solar
