Possible Substitution for Radiator?
2»
  • SusanC
    SusanC Member Posts: 106
    Fin Tube Article and...
    Thanks; I read it but hope there is no quiz.  So far the pipe with small vent sounds like my best bet.  If it doesn't work, I can turn off the supply valve and have a cool (temperature-wise) room.  By the way, and this may be a stupid question, what is a good diameter for the pipe?
  • Noel
    Noel Member Posts: 177
    Same size as valve
    If you go bigger than the supply pipe, be sure to use an eccentric reducer when you connect it, or it will bang.
    If you are tempted to go bigger for some reason, I think a small radiator would be a better idea, like others have said. Output is related directly to square feet of surface area.
  • RobG
    RobG Member Posts: 1,844
    Haven't you heard?
    Susan, everthing you read on the internet is true! I've got a date with french model toniight to prove it!
    Bonjour,
    Nick Nolte
  • SusanC
    Pipe Info
    Noel, Thanks again.  I guess my diameter question wasn't as stupid as I thought
  • jumper
    jumper Member Posts: 2,500
    cheap blanket ?
    SusanC used the wrong blanket. There are blankets that steam can't melt. Why not shut off the radiator & use a wee space heater ?
  • SusanC
    Space Heater
    Thanks; I've disqualified blankets but there is a strong possibility I will go for the space heater.
