RADIANT HEAT
GHAYESQUALITYAIR
Member Posts: 1
I'M WORKING ON 150K BTU BOILER SYSTEM THATS SUPPLING TWO HOMES THE FIRST IS THREE STORIES THE SECOND IS TWO STORIES.THIS SYSTEM ALSO HAS BASEBROAD RADS CONNECTED INTO THE SYSTEM WITH PURGE VALVES.THE RADIATORS ON THE FIRST FLOORS ARE HOT HEATING,THE SYSTEM IS OLD AND IT HAS BEEN FLUSHED SERVERAL TIMES AND BLEED ALSO.
What's your question?
You haven't stated a problem or asked any questions.
Also, please turn the "caps lock" off on your keyboard. All caps means you're shouting.Bob Boan
question
may be the radiators are not heating on the first floor after purging. Dont know which structure or both has the problem though.0 -
how to fill
How did you flush your system ? Are you certain you purged the cold rads? Where is the expansion tank ?0 -
;-) HA HA.... I had to turn my speaker's volume down when I read this thread!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
