Cadet Boiler
ThatGuy95
Member Posts: 1
in Gas Heating
hi I am tring to upgrade my heating system in my house, and convert from oil to gas, on a budget. I know that triangle tube, viseman, and buderus are your best names but due to money or lack there of im tring to stay cheap. I almost bought a navien but am having second thoughts and i stumbled across cadet boilers who i was told made by lochinvar or ao smith. i was wondering if anyone had any experience with them, the model i was looking at is the cnc120 which is a boiler / water heater model. thanks for your feed back
I have never ....
heard of it before. However from the literature it looks like the Munchkin Contender....0 -
Same
Same address as Lochinvar.0 -
Lochinvar Cadet Boiler
The Lochinvar Cadet is an "economical" version of the Lochinvar Knight. The company I work for has brought the line on to compete against the Munchkin Contender. It does not have all the bells and whistles that the Knight has but it is a 5 to1 turn down and the have a combi unit in the 120 model or you can use and indirect tank with it.
The website is www.cadetboiler.com if you want to check it out further.
Good Luck,
Yvonne0 -
Good Luck,
Yvonne0 -
Good Luck,
Yvonne0 -
Thanks Yvonne,
when you post and are ready to submit the post it is a little slow sometimes, just be patient it will succeed!!!0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
