Electronic water feeder/lwco for WeilMcClain Model 80
JEMM55
JEMM55 Member Posts: 47
Which feeder/lwco can i use to replace my McConell 47-2?
I want to be able to monitor feedwater s well.
  • JEMM55
    can i use a vxt?
    850'000 btu with.powerflame burner
  • JEMM55
    can i use a vxt?
  • gennady
    gennady Member Posts: 840
    water meter
    just install small water meter on feed line
    Steamhead Member Posts: 18,184
    edited March 2012
    On 80 series boilers
    there should be two tappings on the front for probe-type low-water cutoffs. We'll put a standard unit in the upper tapping and have that control the VXT. The lower tapping gets a manual-reset LWCO. This not only brings the LWCO setup up to CSD-1 standards, but it gets rid of the moving parts found in the 47-2.
    Here's a pic of a 4-80 we installed that way. The VXT is around back.
    Consulting
