Ray boiler
lchmb
Member Posts: 2,997
Has anyone installed or serviced the Ray condensing boiler? Curious as to opinions on the system...
no one?
.....0 -
Recent update to an older post
I saw an update to this post:
http://www.heatinghelp.com/forum-thread/130753/How-is-rAy-these-days
TimWinter Park, CO & Arvada, CO0 -
thanks
I should have gone looking..if it's heating related it's here some place...Thanks!!0 -
Tom I have
an old Ray in my center which has the faulty ignition control on it and I have to get it updated. When I do I will have some information on the Ray and what is happeneing with it.0 -
Thanks Tim
Much appreciated!!0 -
Ray boiler
I have one installed in my home with in-floor on two zones and an triangle smart 40. My issue is trying to find an electrician to wire it. I installed a primary-secondary loop system and can't get it to run correctly. He left today and I get home and find out the heating is working while my indirect is calling for heat. He took out my taco 6 zone box and kept in the taco circuit relay. ?????? I am trying to prevent high water temp. to run underneath my hardwood floor so it does not warp. Thanks to my hardwood installer, I now have a hole in my basement ceiling trying to locate which zone is leaking. Any one have a tylenol?There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
