Ray boiler
lchmb
Member Posts: 2,997
Has anyone installed or serviced the Ray condensing boiler? Curious as to opinions on the system...
no one?
.....0 -
Recent update to an older post
I saw an update to this post:
http://www.heatinghelp.com/forum-thread/130753/How-is-rAy-these-days
TimWinter Park, CO & Arvada, CO0 -
thanks
I should have gone looking..if it's heating related it's here some place...Thanks!!0 -
Tom I have
an old Ray in my center which has the faulty ignition control on it and I have to get it updated. When I do I will have some information on the Ray and what is happeneing with it.0 -
Thanks Tim
Much appreciated!!0 -
Ray boiler
I have one installed in my home with in-floor on two zones and an triangle smart 40. My issue is trying to find an electrician to wire it. I installed a primary-secondary loop system and can't get it to run correctly. He left today and I get home and find out the heating is working while my indirect is calling for heat. He took out my taco 6 zone box and kept in the taco circuit relay. ?????? I am trying to prevent high water temp. to run underneath my hardwood floor so it does not warp. Thanks to my hardwood installer, I now have a hole in my basement ceiling trying to locate which zone is leaking. Any one have a tylenol?Wanting to do it right0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
