furnace not staying on
noheat
Member Posts: 1
in Gas Heating
hello
I have a pretty new furnance 2 yrs old;however the fire from the burners aren't staying on due to the air from the blower. Brief description of what happens: the fire come on the the blower. It stays on for several minutes with heat blowing from the vents. When it goes off, it resets the fire comes back on from the burner. Then blower blows out the fire. What could it be. Please help
Thanks
Thanks
I Don't Understand Your Description...
But you're gonna need a serviceman. This is not something a H.O. can work on.Bob Boan
What is the make
and model number. Please identify some controls (numbers and make help) and we will get back to you in the meantime have it serviced by a professional.Is the original installer available?0 -
Check filter
Sounds like its going off on high limit and I bet your filter is clogged. Also make sure all the registers are open.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
