furnace not staying on
noheat
noheat Member Posts: 1
hello
I have a pretty new furnance 2 yrs old;however the fire from the burners aren't staying on due to the air from the blower. Brief description of what happens: the fire come on the the blower. It stays on for several minutes with heat blowing from the vents. When it goes off, it resets the fire comes back on from the burner. Then blower blows out the fire. What could it be. Please help
  • Ironman
    Ironman Member Posts: 7,859
    I Don't Understand Your Description...
    But you're gonna need a serviceman. This is not something a H.O. can work on.
    Bob Boan
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    What is the make
    and model number. Please identify some controls (numbers and make help) and we will get back to you in the meantime have it serviced by a professional.Is the original installer available?
  • Slimpickins
    Slimpickins Member Posts: 359
    Check filter
    Sounds like its going off on high limit and I bet your filter is clogged. Also make sure all the registers are open.
