Can this Gas Meter be moved? If so, how much? Cost? (see photos)
  • Ironman
    Ironman Member Posts: 7,730
    That Would Depend ...
    Upon what your gas company allows and what a local contractor would charge.
    Dan's first rule posted on "The Wall": "Please Don't Discuss Pricing".
    Bob Boan
  • Tim McElwain
    Tim McElwain Member Posts: 4,656
    Yes it can be moved
    In some areas the gas company wants to get the meters from inside to outside. Check with your local gas company to see if they are interested in doing that for their convenience. Does a meter reader read your meter or is it read electronically?  If it is a meter reader then outside is to their advantage. They will also tie in to your outlet and relight your equipment.
    What is using gas in the house?
