Timmie-- honeywell gas valve question.
gerry gill
Member Posts: 3,083
in Gas Heating
on the new atmospheric boilers with honeywell gas valves..the regulator adjusting screw used to be a straight slot type screw..now its something that a straight slotted screwdriver fights with..it looks like a star-ish shape..what is it? is it torx?
gwgillplumbingandheating.com
Is this a Honeywell
VK 8115 valve? if so it is a European Honeywell valve. Depending on whose boiler it is located it is not to be touched. There will typically be a throttling screw on the valve/draft inducer set up. With make, model and whose boiler I can give some further information.0 -
no its a VR something..
when i go back to skim i'll get the valve numbers..its oem on the peerless atmospheric steamer 64-08..gwgillplumbingandheating.com
Gerry e-mail me a picture
if you can and I will take a look at it. I am at gastc@cox.net0
