Boiler replacement
jim_72
jim_72 Member Posts: 77
My Parish's  needs a new Hot Water replacement boiler. Current boiler is a Federal # FMA-1425 - Carlton gun 13.80 fire rate- gross output 1553000- #2 oil. This will be used as the new main( there is a auxiliary boiler)to also make DHW during winter months. Would greatly appreciate any info as per a replacement unit  Burnham three pass-Peeless-WM-Smith  etc. from the commercial side.Thanks so much Jim
  • grumbug
    grumbug Member Posts: 7
    BOILER REPACEMENT JOB
    WHAT ABOUT A NICE COMMERCIAL BOILER REPLACEMENT.
        BUDERUS G315/9  X2
        TACO EXP ZONE CONTROL  AS MANY ZONES AS NECESSARY
        TACO PC 702 STAGING CONTROL
         REPLACE PUMPS AS NECESSARY    ETC
  • grumbug
        BUDERUS G315/9  X2
  • grumbug
    BOILER REPLACEMENT JOB
    MOST HEATING PROS ARE NOT ENDORSING BURNHAM PRODUCTS!!!!!!!!!
  • Ironman
    Ironman Member Posts: 7,855
    Agreed
    Buderus has (arguably) the best cast iron boilers on the market. Adding staging and outdoor reset should substantially reduce fuel consumption.
    Bob Boan
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Absolutely not true!
    Burnham sells more boilers in the USA than Buderus by far,so somebody must like them!  On the oil side,I'm pretty much a Buderus guy but there is absolutely nothing wrong with the MPO and the Megasteam is hands down the best resi steam boiler out there.
