Boiler replacement
jim_72
Member Posts: 77
My Parish's needs a new Hot Water replacement boiler. Current boiler is a Federal # FMA-1425 - Carlton gun 13.80 fire rate- gross output 1553000- #2 oil. This will be used as the new main( there is a auxiliary boiler)to also make DHW during winter months. Would greatly appreciate any info as per a replacement unit Burnham three pass-Peeless-WM-Smith etc. from the commercial side.Thanks so much Jim
BOILER REPACEMENT JOB
WHAT ABOUT A NICE COMMERCIAL BOILER REPLACEMENT.
BUDERUS G315/9 X2
TACO EXP ZONE CONTROL AS MANY ZONES AS NECESSARY
TACO PC 702 STAGING CONTROL
REPLACE PUMPS AS NECESSARY ETC0 -
BUDERUS G315/9 X2
BOILER REPLACEMENT JOB
MOST HEATING PROS ARE NOT ENDORSING BURNHAM PRODUCTS!!!!!!!!!0 -
Agreed
Buderus has (arguably) the best cast iron boilers on the market. Adding staging and outdoor reset should substantially reduce fuel consumption.Bob Boan
Absolutely not true!
Burnham sells more boilers in the USA than Buderus by far,so somebody must like them! On the oil side,I'm pretty much a Buderus guy but there is absolutely nothing wrong with the MPO and the Megasteam is hands down the best resi steam boiler out there.To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
