EK system 2000 water tank replacement
My tank is leaking & the tank itself is under warranty so I just need the new one installed. I was quoted for labor & miscellaneous parts, it is way more than I paid to have the new tank installed only 4 years ago. I know prices increase and I don't mind paying for good work but this feels like they are just trying to take my money. I did not realize I was not supposed to discuss price, so i edit. But I am surprised, because the guy told me it would only take an hour and a half & it sounds like it's actually a much bigger job than that.
So this is the third tank? Or the whole EK system is 4 years old and you got estimates for with and without the water heater?
This will be the 3rd tank. EK System 2000 was existing in the house when we purchased in 2021, then early 2022 had to replace the tank. Now the new one is leaking but is under warranty, the 3rd one will have no warranty.
1 -
what has EK said about the failure?
@pecmsg ek rep is the one who told me it was an easy 90 min job & confirmed it was under warranty for me.
Was he on site to inspect?
Those tanks should last a lot longer than that. I work on a lot of EK boilers and have one in my own home. It's not uncommon to see one of those tanks last 15-20 years even when not maintained properly. Has anyone inspected the condition of the sacrificial anode rods in any of the tanks? Have you had your water tested?
I believe EK offers a plastic lined tank for homes with poor water quality. I recommend installing a powered anode to replace the standard magnesium sacrificial anode rod.
3 -
Have you had the water quality checked? Any issues with the plate heat exchanger or Flo check in the 006?
Keep up on checking/replacing the anode rod with the new tank.
had EK reported the cause and reason for multiple failures?
Yeah here came to see it b/c he said they don't usually fail.
The original tank was taken away by the prior company when this one was put in but no one said what caused the issue.
- 16.2K Strictly Steam
- 52 Job Opportunities
