Steam boiler replacement
hi guys.
Quoting a steam boiler replacement I’ve measured all the radiations and determined I have 425 sq ft or steam and 426 edr. My question is that on this boiler the supply is 2” but the existing boiler currently has 2 3 1/2 supply’s. Should I be worried sizing the boiler to the radiators and leaving the current supply piping?
Are you a contractor or homeowner?
Your question is somewhat strange to read but I'll answer it how I read it without comment as to any other concerns:
You can use your existing 3-1/2" supply (near boiler) piping with your new boiler.
But send some pictures of it because we like to look at pictures.
each main should connect separately to the header for the new boiler. if there is a header from a previous boiler still there you need to remove it and bring the mains individually down to the new header. the connections to the header should be ordered as: all the supply risers from the boiler, all the risers to the steam mains, the equalizer. you may need to make the header a loop or rotate the boiler or other creative arangements to accomplish this.
If there really is 3 1/2" piping that will all have to come out as the fittings basically aren't available so you can't really work with it. Some boilers only list a single tapping as being needed, but have a second available if you want to use it, depends on boiler brand
you can even get 3.5" pvc threaded plugs(not for steam use but 3.5" stuff is out there just maybe not sitting on the shelf locally or inexpensive)
