Normally boiler shuts off at 67F. Now, it's running until 69F. What changed?
I know specific degrees do not matter. It's all relative, etc.
My $15 digital thermometer is located across the room from the thermostat. Thermostat in living room. Works great. Normally boiler shuts off at 67F. Now, it's running until 69F. What changed? Does cold snap somehow affect? Thermostat has not been touched all winter.
If you want to verify if the thermostat is reading temp. correctly then you need to locate that digital thermometer right next to (but not obstructing the airflow to) your thermostat.
Edit to add - One of the best things I have done is to add a remote temperature sensor which I located in a different location of my 1st floor, away from the thermostat. I am much more comfortable with the thermostat averaging that remote sensor input with it's own internal one.
Edit to add - I bought one of these wireless temperature/humidity sensors a few years ago (price is $2 higher but it is still cheap) and have it parked right on top of my WR digital thermostat. There is an app on my phone that gives me a graph of the days temperature reading and no matter where I am I can monitor what the temperature is to see if my thermostat is doing a good job or if there is a problem with my boiler and if the thermostat is being honest. https://www.amazon.com/dp/B0CHRZ26GM?ref_=ppx_hzod_title_dt_b_fed_asin_title_0_1&th=1
What make and model thermostat? Its possible the anticipator or CPH is not correct and it's overshooting during the cold spell.
You're getting the temperature readings from the digital thermometer? How close is the thermometer to a heat emitter? Does the thermostat show 67° when it shuts off?
It's not about the actual temperature.
Normally, my boiler shuts off at X degrees.
Now, it's shutting off at X+2 degrees
I never touched the thermostat.
@EBEBRATT-Ed might be onto something. The wall with the thermostat might be getting colder than usual, relative to the digital thermometer across the room, with deep freeze, so boiler is running longer,
Thermostats should be on an internal wall. The hole in the wall that the wires come out of behind the thermostat, I always stuff with fibre glass insulation to keep the cooler air in the wall cavity from acting with upon the thermostat.
What type of heating system?
Chronoterm Honeywell
Oil/steam
What model Honeywell Chronotherm?
Just an observation, but as outdoor temps drop in my single pipe steam, my heating system seems to operate even better to heat the house. In my case, after the heating cycle ends, the temperature rises about two degrees naturally. This is followed by the temp slowly decreasing to set temp. to begin next cycle
I dont pretend to understand the physics behind it, but it works for me
Regards,
RTW
could be overshooting due to higher pressure in the system (which raises the temperature above 212) and all fully hot radiators at the end of the call for heat
See my sight glass boiler videos: https://bit.ly/3sZW1el2 -
Radiators continue to heat the room after the boiler shuts off. On mild days the thermostat may shut the boiler off at set temperature with the radiators ~50% fille. On cold days it may do same with raidators will to 90% or 100%. The more filled raidators will heat the room more in their process of cooling leading to more overshoot. This of course is different from the issue of the thermostat not shutting off the boiler until real room temperature has already overshot which would be related to the thrmostat location.
2 -
I never closed this out. Good point about the rads getting filled, and maybe having more residual heat. But the rad in the room always fills us. So, I think it was due to an extreme cold snap. Thermostat is not on an exposed wall. It's on the left side of the room. But, my digital thermometer is on the right side of the room. Boiler runs until digital thermometer reads 67, but in the cold snap, it would run until 69. I think the windows were causing an short-range imbalance of heat in the room. Once temps got back to 20/30s, the boiler would stop at 67 again. Thermostat was never touched.
You are introducing variables that are not related to your system. The digital thermometer is rather irrelevant to when your boiler turns on or off. The thermostat is the source of truth.
I get that, but the issue was that it was 6* outside, and the thermostat was turning off later, for some reason. I suspect the wall was colder than normal.
Yup.
Two thermometers reading slightly differently? Even if placed right next to each other? Unless you are dealing with calibrated laboratory grade thermometers, it will be a wonder if they are closer than 5 degree. Never mind if they are in different places in the room…
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
