Cracked cast iron rad
rjean
rjean Posts: 3
edited January 2025 in THE MAIN WALL
I have had three radiators crack all at separate times all while the heat was on and radiators were hot. What causes this
    Jamie Hall Posts: 27,815
    Any number of reasons why a piece of cast iron would crack — eventually. Restraint on expansion or contraction, over pressure, impact… all usually starting from minor irregularities in the casting…
    To have three on the same system crack over a short period of time makes one want to look for a common factor, though. Could be as simple as the way they were shipped. Need to know a lot more.
    ethicalpaul Posts: 9,012
    is it definitely a crack or is it a rusted hole?
  • Waher
    Waher Posts: 373
    pictures?
  • rjean
    rjean Posts: 3
  • rjean
    rjean Posts: 3
    I believe it’s my pressure building up how do I stop it from building up
  • jesmed1
    jesmed1 Posts: 1,585
    edited January 2025
    What is your boiler pressure relief valve setting, and have you ever exercised it (ie opened the valve to make sure it's not frozen in place)?
    mattmia2 Posts: 18,099
    Having previously frozen or severe corrosion seems like the only way. For baseboard like that freezing seems much more likely.
    jesmed1Long Beach Edkcopp
  • jesmed1
    I was going to say, looks like a crack you would expect from having it freeze full of water.
    pecmsg Posts: 7,549
    there is no way that boiler built up enough pressure to break that radiator!
    I agree it looks like a previous frozen weekened and finally let go
    mattmia2kcopp
  • ScottSecor
    ScottSecor Posts: 1,056
    Is this a hot water or steam system?
    It is very rare for cast ion heat emitters to crack. Cast iron baseboard may be more prone, but we rarely see them crack under normal circumstances. If water froze inside it could certainly cause a crack.
