union and flex pipe on main steam line
sz9
sz9 Member Posts: 27
thoughts on installing a union on the main 2 inch line and a flex hose to the radiator. one pipe steam system
Mad Dog_2
    ethicalpaul Member Posts: 8,933
    Are the union on the main 2" line and the flex hose related in some way I'm not understanding?
    The answer to the flex hose question is almost certainly "don't do it" but out of curiosity, what material is the hose?
    EdTheHeaterMan Member Posts: 12,506
    I was wondering if you might be interested in some steel tubing to use as tires instead of those rubber ones you have now. They would last longer then the rubber ones for sure.
    Mad Dog_2SuperTech
    Now Ed…
    delcrossvEdTheHeaterManSuperTech
  • delcrossv
    delcrossv Member Posts: 2,204
    Well they do call them "radiator hoses". On a car….
    ethicalpaulPC7060SuperTech
  • KC_Jones
    KC_Jones Member Posts: 5,939
    Have you priced out a steam rated flex line in the appropriate size?
    I only ask because one of our steam test labs has a flex line (much more than 2") and that material is a lot of money. I'd speculate more than paying a professional to pipe it in black for you.
    2014 Weil Mclain EG-40
  • sz9
    all joking aside. need to relocate a first floor radiator by about 6 inches. . as far as the flex hose i was talking about a stainless braided hose recommended for high heat and pressure.
  • delcrossv
    Joking aside, why go to hose? Just put a nipple and/or a straight radiator valve on it.
    ethicalpaulIronmanMad Dog_2SuperTech
  • Ironman
    Ironman Member Posts: 7,927
    edited October 2024
    If it’s braided, then the interior is most likely rubber and I would not use that on steam. It’s also gonna be a smaller ID.
    Bob Boan
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    My thoughts are do the job the right way or you will have a mess on the coldest Friday night of the year when there's nowhere open to buy the parts needed to cap the leak the Chinese hose causes.
    IronmandelcrossvMad Dog_2SuperTech
    EBEBRATT-Ed Member Posts: 20,481
    As @KC_Jones mentioned you can get steam rated hose but the $$$$$ will make it not worthwhile.
  • sz9
    ok. thanks for the advise, was just a thought. i will re pipe with black iron. safe and reliable.
    delcrossvSuperTechIronman
  • jumper
    jumper Member Posts: 2,581
    Abbatoir sterilises with steam. Presumably hoses?
    And the steel pipe will not sag and leave a pocket or trap for condensation to lay there causing other problems.
    Ironman
  • ScottSecor
    ScottSecor Member Posts: 1,042
    edited October 2024
    I have seen stainless steel braided hoses used on high pressure steam kettles. They even had quick connects on the ends so the staff could swap kettles the size of a Ford refrigerator (yes, that Ford) in a hurry.
    However in your case, I also recommend steel pipe and cast iron fittings. I think ss steam rated hose would work if only used vertically. If used horizontally, would likely sag and cause banging.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,680
    Most times, you waste more time taking "shortcuts" and Gerry-Rigging things. Bite the bullet now, and put it behind you for life. Mad Dog
    STEAM DOCTORIronmanBobCdelcrossv
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,622
    For the record, black fittings will work fine as well. Don't necessarily need cast iron fittings. But of course everyone has their preference.
